timing advancement mod
Old 07-30-2004 | 09:21 PM
1fasthatch's Avatar
Traction Problems
If you want to do it correctly try this!!!!!
http://www.c-speedracing.com/howto/timing/timing.php
James
www.artofspeedproductions.com
Old 07-30-2004 | 10:34 PM
blurboEK's Avatar
proud father ;D
James
that would be for a B-series and I highly doubt his 4th gen prelude has a B-series motor.
93lude...
behind your radio you'll see a blue plug, this is your service connector. get a wire, paper clip, etc and place it into both holes. check engine light will come on when you start the car.. this is good..
Now remove the rubber plug located next to your block stamp. This will expose your flywheel.
Take your timing light, connect to positive/negative battery terminals, attach to #1 plug wire, aim at the flywheel and pull the trigger.. you'll see a flash of light and on the flywheel you'll see a groove cut. move the distributor until the light and the grove match up, tight the 3 bolts, remove wire from service plug and take her for a spin..
If you want to advance your timing, purchase a timing light with that option. Craftsman sells one for $70.
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
Old 07-30-2004 | 11:10 PM
Big Chris's Avatar
tampa car scene
Pillow fight.
Old schooler.
Old 07-30-2004 | 11:41 PM
Suspect's Avatar
Certified since '85
I tried the timing trick and help low end when you advance it......but sux ass high end unless it retarded......
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old 07-31-2004 | 06:15 AM
terry.ho's Avatar
I love to choke people.
Originally posted by 93g2integra Chris
Pillow fight.
If your talking about Keith it would be pillow biting.
Originally Posted by fresh&clean
This is the worst place to get any advice at all.
http://www.myspace.com/terry_ho
Old 07-31-2004 | 08:42 AM
  #17 (permalink)
93redlude's Avatar
realfucnfast
That is a a lot of helpful info. From what most of you all are saying it is just better to keep it the way it is. Thanks......Dave
Old 07-31-2004 | 11:44 AM
  #19 (permalink)
terry.ho's Avatar
Originally posted by `92CXhatch
wow your not gay...[/sarcasm]
It's you Keith. Your just sooo hot. I just want to smother you in gravy.
