howe tp verify a true h22a type s?
the engine has been pulled so i odnt think a dyno could be possible, but are the codes encrypted ont eh block good enough to check if the engine is a type S? whats the best and easiest way to find out without a dyno or previous tittle? thanks
The Casting numbers on the block should be able to tell you.
Need your Honda/Acura tuned? Ecu Chipped?
Http://www.Phearable.net
Need some Stereo/Security/Video Work Done? Almost Anything 12 Volt I can do. 12 Years Experience. Send a PM For Inquiries.....
