what arp head studs do you use when running a b16 head/b18c block?
Old 03-04-2008, 05:35 PM
94jdmgsrdriver's Avatar
Default what arp head studs do you use when running a b16 head/b18c block?
Just as title says. i thought you could interchange them.. but prefer know then assume.
Old 03-04-2008, 10:15 PM
civicized's Avatar
just get the ones for a b16 head on an LS/B20 block and you are good.
Old 03-05-2008, 03:25 AM
I-VTEC, do you?
itsslow's Avatar
No, you wont be using the Ls/Vtec studs.
Call ARP and ask them.
Old 03-05-2008, 06:32 AM
civicized's Avatar
Yes, you will be using the lsvtec studs. I am not sure what itsslow's objection is, but it is really simple if he thinks about it.
You are putting a b16 head on a block that has the same deck height as an LS block. Remarkably enough, the ARP studs don't know that the engine block says b18c on it rather than b18b. Stupid studs!
Aslo, I've got a gsr with a b16 and lsvtec hed studs that's been on the road for about 8 or 9 months now. Just purring along with 20 pounds of boost.
Old 03-05-2008, 10:59 AM
I Called ARP today.. and this is what they told me.... The b16 and b18c1 head bolts are pretty much identical..both 11mm and only off in length by the thousands.he said it would be just fine using my b18c1 arp head studs for my b16top/b18c bottom.(woohoo).and i ask them about the washers because i have a gsr arp head stud kit that came with the main stuid kit as well was missing 3 washers for the head studs..i asked to order the 3 missing washer and he just reccomended i bought them locally..saying that the oem washers would be just fine.its the head studs that are the real difference... for anyone else that was wondering...
Old 03-05-2008, 11:11 AM
DjNando's Avatar
Thanks for the info from ARP JDMDRIVER!
Old 03-05-2008, 02:04 PM
no prob man.. just felt that was some direct info from ARP that others would like/need to know as well... love this site..its helped me out alot with my build up
Old 03-05-2008, 04:14 PM
I-VTEC, do you?
itsslow's Avatar
^ Yes, Thanks for sharing the info.
Old 03-05-2008, 07:22 PM
civicized's Avatar
b18c and lsvtec studs are the same length because they are for the same block height. The b16 block is shorter.
Old 03-06-2008, 03:14 AM
i def understand that.. i mean.. dont u just cut a inch or so of the bottom of a b18c and bam, u got you a b16(sorta speak). what i mean is.. does the block matter since i would assume what matters is the length in thread that bolts threw the top of the block from the head studs?
