Help Clutch not disengaging
Old 06-27-2001 | 08:47 PM
DaBman's Avatar
Ok I got in my car started it up and realized there was no peddle pressure at all on the clutch I have an act racing clutch. When i went to put the car in gear my clutch wouldnt disengage so i couldnt put my car in gear to drive. Also before this happend i would grind going into 3rd gear when shifting past 4000 rpm.
Does anybody know what the problem could be.
Thanks
Bryan
Old 06-27-2001 | 09:54 PM
BIG_Truck_Driver's Avatar
Wherever I may roam...
Just curious why you think his tranny is bad when he has no clutch pedal pressure?
I am not familiar with the design of that clutch but that is exactly how mine acted when one of the springs broke in the center of my clutch essentially locking the clutch engaged.
Old 06-28-2001 | 08:01 AM
KJ's Avatar
KJ
bored at work
what year is your car? what model?
Old 06-28-2001 | 08:49 PM
DaBman's Avatar
its a 94 prelude si
Old 06-29-2001 | 10:50 PM
marksaccord95's Avatar
TR Registered Member #5
go check the fluid level for the clutch. I bet there is nothing there or if not I bet its either the master or slave cylinder check around them for leaks of the clutch level is completely full..... make sure you check the right resovar(SP?)
http://www.floridaracing.org
Old 07-01-2001 | 07:56 AM
DaBman's Avatar
well i dropped my car off yesterday and had my mechanic look at it and it ended up being the slave cylinder. So it was 150 bucks to get it done but my car was back in a couple of hours.
Thanks for all of the input.
Old 07-02-2001 | 10:32 PM
Damn im good!
FastFour
01-22-2001 08:56 PM
