Check Engine light/Test pipe...
I just installed a test pipe on my civic and it ran smooth but today about 15 hours after installation the Check Engine Light came on. What could this be from?:barf:
Do not store up for yourselves treasures on earth, where moth and rust destroy, and where thieves break in and steal. But store up for yourselves treasures in heaven, where moth and rust do not destroy, and where thieves do not break in and steal. For where your treasure is, there your heart will be also.
--Matthew 6:19-21
--Matthew 6:19-21
I believe your O2 sensor was in your cat therefore it is no longer on your car which with obd2 just doesnt work. Give me a call tomorrow (friday) and Ill take a look 215-4830
-alan
-alan
The sensor is hooked up to the test pipe how can I get rid of this check engine light? Take the negative terminal off the battery? Then when I replace it it will turn off right?
--Matthew 6:19-21
--Matthew 6:19-21
oh you did connect it? As long as it is connected properly try resetting the ecu. If it stays on then Bill is right on the money (surprise surprise) and its going to stay on.
Take it to the dealer and ask them to reset it. I know that they will ask but take it to a Honda dealer that you didnt get your car from and just ask them to reset the computer. It will go away. Thats what happened with my Golf.
2003 Volkswagen GTI 1.8T Silverstone Grey
Here is the correct answer:
Why that check Engine light? Because the second O2 sensor is not reading the correct values due to the loss of the catalytic converter.
How to overcome this?
1. Put Cat back in.
2. Covert to OBD 1 $$$
3. Smash Check engine light bulb
4. DEAL WITH IT.
Some say you can do some Tin foil trick but havent heard if it really works.
Either way unless you are running extremely high compression or Forced induction you will actually loose power due to lack of back pressure. I/H/E just arent enough to justify it. Sure it may SOUND faster...but it isnt. Sorry.
Charles
1. Put Cat back in.
4. DEAL WITH IT.
Charles
My Blog: www.HotRodCaddy.com
Guest
Posts: n/a
It seems that all Hondas have a preferance for different resistors but a 10K - 12K unit should do the trick for the secondary sensor signal. You can find them in packs of 5-6 at RadioShack for next to nothing.
A pair of wire cutters a little soldering some tape and yourre done. If you have the Helms manual to find the correct wire it can all be done inside the car at the ECU.This should fix your problem.
