1.6 SOHC VTEC Head on 1.5 SOHC NON-VTEC Block
Guest
Posts: n/a
yeah its a great swap and easy to some new things you will need is a 92-96ex-si head gasket new head studs ecu and wire it up for vtec or msd rpm switch wich does not require a vtec ecu(p2 also you will gwt a higher compression with the head swap your compression should go up to the likes of 11.1 because of the smaller combustion chamber.
Guest
Posts: n/a
the compression will go up but not as much as what hybrideg said it will be around 10.3:1-10.5:1 depending on the head gasket you use. If you use a 92-5 headgasket it would be around 10.3 if you use the 96-00 ex headgasket you would get around 10.5:1. The 92-5 headgasket is .048 inches while the 96-00 ex headgasket is .028 inches.
Robster
Robster
sorry i did give the the wrong answer i thought it said that he had a d16y8 head. next time ill try to look a little harder and the post. the y8 give you compression in the lower 11s 11.2-4
that's president hussein obama to you :gordy:
Guest
Posts: n/a
no a y8 head on a 1.5 block will not give that high of a compression. The numbers I gave were for the y8 head. A z6 head will be .2 less than the y8.
Robster
Robster
