Injector sizes and hp values...
Old 09-06-2002 | 05:47 PM
99B16Si's Avatar
u can run about 11-12 psi on those, maybe more but put youll be maxing them out. you can get a lot more than 195hp out of those
Old 09-06-2002 | 06:50 PM
91TSI_AWD's Avatar
Resident Galant Guy
I have a set of 450cc injectors for sale. as far as fuel/boost/compression... Higher compression with less boost = lower compression with more boost. more fuel is used on the lower compression setup cause more air is going throught the motor. but the lower compression setup will also take more boost on pump gas, where as if boost is turned up on the high compression setup a better fuel system is needed(Fuel Pump, injectors, rail, regulator) or a higher grade of octane(100,110).
Mike
95 Lancer GSR
93 300ZX 2+2
