View Poll Results: How should I go about this repair?
Remove, rebuild, re-install current transmission?
100.00%
Purchase used, rebuild and replace?
0%
Voters: 1. You may not vote on this poll
b16a2 Throwout bearing or diff?
Old 02-21-2011 | 07:30 AM
SiADub's Avatar
Default b16a2 Throwout bearing or diff?
I've had a bit of a whining in my tranny only under a load for some time now. Just recently started getting worse. More "crunchiness" (for lack of a better word) in the already present whining.
The other day, on my way home. I started to smell something like a brake smell or (hopefully not) clutch smell. Im not sure if it was actually me or not, brakes were working fine and clutch still grabs as good as it did on day 1. I was on the interstate with a lot of other people around me. It only concerned me because it wouldn't go away.
Then started to hear a pop noise from the transmission. I could feel it a little bit in the shifter. It was constant only when the gas was applied. Put it in neutral and rev and coast, nothing. Any one have any insight on what the problem may be?
Old 02-24-2011 | 06:50 AM
SiADub's Avatar
Old 02-24-2011 | 08:21 AM
jDmEK00's Avatar
Team Asimo FTW!!
if it was the throw-out bearing you'd hear a rattling noise everytime you let off the clutch, & when its pressed it'll go away. So throw-out bearing? I'd say no!
Team Asimo FTW !
[BIG][/BIG]
STOP SUPPORTING THEIVES. DONT BUY STOLEN PARTS.
show your support and copy this into your sig.
Old 04-08-2011 | 07:35 AM
SiADub's Avatar
Yeah, I figured. It wound up being the ring gear and the counter shaft gear. Both were missing teeth. Ugh! Replacing with LS parts and I bought carbon synchros and new, updated bearings and seals from Synchrotec. Hopefully will have it back together by the end of this weekend. Hopefully!
Old 04-12-2011 | 04:05 AM
sean83's Avatar
I know the problem has been figured out but this statement is incorrect ... that would indicate a bad input shaft bearing.
Old 04-13-2011 | 08:35 PM
boogieman2188's Avatar
+1
Old 04-13-2011 | 09:30 PM
sburtoncivic98's Avatar
i go with input shaft bearing
TR "Old Skool EF" Member #210
eightwun3zfynest
For Sale/WTB Honda & Acura
01-17-2010 08:51 PM
sm6989
11-06-2006 09:24 PM
Cronic
11-21-2002 08:46 AM
