is the half shaft of a b18b1 the same as the half shaft of the b18a1!!!!!!!!!!!!!
i waz reintaling the axles and found out that the half shaft wasnt alining with the bolt holes on the block so is it that DAs and DCs half differnt half shafts because i got a 93 DA with b18b1? plz help .......do i got to bang it in with a hammer or wut??? plz help thanks
They should both bolt up to the b series block. The difference between them is that the da half shaft has a female end and the newer half shaft have a male end. Make sure both are b series halfshafts. Hammer shouldnt be needed if the axle is already off the shafts. It should slide right in (all the way in the tranny) and line up with the the 3 hole in the back of the block
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
so that means i might need a dc half shaft cuz i think thats wuts going on cuz i had a b18a1 tranny in it but it blew so i bought a ls iam figuering differnt year and it looks like the half shaft aint alining so its prob that i need a DC half shaft right??
The problem your having is one is for an auto trans and one is for manual. I have an extra DA manual trans half shaft I will gladly sell you for $30 if you want it.
iantoma55
For Sale/WTB Honda & Acura
6
03-15-2011 07:19 PM
marktopia
5
07-08-2008 02:14 PM
