Non starting issue..92 Acura Integra
Old 10-11-2011, 03:23 PM
greenteg1992's Avatar
Default Non starting issue..92 Acura Integra
I have a 92 integra that does not want to start. The car can be push started, or started if you put a wire from the battery to the starter. I was told when I bought the car the starter was going bad. I did not have any problems and I drove the car all the time, but sometimes I would not start and I would just have to wait overnight and it would work fine, and that only seemed to happen if I drove often throughout the day.
So my clutch went out and we replaced it, and now the car will not start with the key at all..
Anyone have any ideas or experience with this? I have heard ignition, starter, etc.
FYI there are very little grounds in the car for whatever reason (only 1 on tranny, starter)
Thanks for reading..
Old 10-11-2011, 06:48 PM
Kenpo Master Technician
Sno Wyte's Avatar
Does it try to turn over? weem weem weem weem weem
Originally Posted by BoostedRacerDad
When my vtec kicks, time and space collide....yo
Originally Posted by jst4shw
real rota wheels
Old 10-11-2011, 07:04 PM
! Ne shab'rud'ni !
chi town brat's Avatar
It could be the ignitor or the coil as they will cause intermittment issues. You can test them before you replace them.
by http://www.flickr.com/people/8341770@N07/, on Flickr
Old 10-11-2011, 07:16 PM
it doesnt even try to turn over. lights come on battery is good, nothing just even tries to turn over.
Old 10-11-2011, 07:38 PM
turbo hhhmmmm?
luvsracin87's Avatar
It could be the saftey switch on the clutch pedal
Old 10-11-2011, 09:05 PM
Pops
BoostedRacerDad's Avatar
There are 2 fuses in the underhood fuse box to check real fast. .Check out fuse #30 (80 amp) which sends power to fuse #32 (50 amp) which then sends power to the ignition switch.Then it sends power through the neutral safety switch down to the starter.
Start by bypassing the clutch switch which is at the top of your clutch pedal. Jump the two wires together.(The lower switch is for cruise control)
Try to start car, if start replace switch.
If not see if you are getting 12vdc at the single wire to the solenoid on starter when cranking.
If not sounds like ignition switch electrical portion is bad.
I think Luvsracin87 will be right due to the age of your car.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old 10-11-2011, 10:23 PM
Sno Wyte's Avatar
+1
real rota wheels
Old 10-11-2011, 10:25 PM
Sno Wyte's Avatar
+1 for pops, he knows his stuff
real rota wheels
Old 10-13-2011, 07:20 AM
Hey its that guy!!
Thatguysstuff's Avatar
thinking the Safety switch on the clutch pedal.. Stupid little rubber grommets always like to break and fall out.. like a 3.00 part from Honda.
Old 10-13-2011, 09:26 AM
customkid72's Avatar
yo thanks for the help boosted i looked at it ...checked the fuses also jumped the switch and still doesnt start i checked the grounds and all thats left if the check the wire amp ...thanks alot man its people like you that keeps peoples heads up when i comes to the car game
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Quick Reply: Non starting issue..92 Acura Integra
