Any advantage to slightly larger dia. tires in front..say 215/45 F and 215/40 R ??
Old 02-10-2003 | 07:49 PM
jay90si's Avatar
Kimbo Slice
Default Any advantage to slightly larger dia. tires in front..say 215/45 F and 215/40 R ??
I have noticed that a few cars, mostly fron tuners in japan are running like a 45 series tire in front versus a 40 series in the rear. And these cars weret drag cars either. Whats the advantage to this? i read a little on this once but forgot?..thanks
jay f.
A little FI comming soon to the prelude...
Old 02-10-2003 | 11:13 PM
KiddStarr's Avatar
Originally posted by Vapor
less sidewall in the rear allows less flex, thus the tire begins moving easier. This would help the rear come out.
The popular size to use in japan is 205/50/16 fronts and 195/45or50/15 rears
what he said....
Im happy with my 205/40 series....
Old 02-11-2003 | 03:45 AM
jay90si's Avatar
Kimbo Slice
yeah i'm running 215/40 now..need to get new tires just checking out my options. Also the thicker tires in front would help it absorb more bumps right...i.e. less wheel hop..but that would be more for drag racing, but then again it would also help out if i was going through a bumy turn..hmmm..Think i'll stick with 215/40 all around instead of experimenting though..dont have enough cash to be dicking around...thanks
jay
Old 02-11-2003 | 07:59 AM
95gsr's Avatar
AlKiF4i
i guess i would kinda be popular in japan w/ 205/50/15's yeaaaa.
Old 02-16-2003 | 03:13 AM
Sunrise City Rider's Avatar
WHAT!?! OK!......
Larger Front Tires will help reduce understeer because their is more contact patch for the Front End to pivot on...Causing the Rears to Break away and rotate...Breakaway limit and speed depends on the rubber compound of the tires...
Zee
