tie rods ends..
i had this problem outer tie rod is the closest to the tire. inner is furthest to the tire. dont go to auto zone looking for one they are dumb fucks. i got mind at discount for a bit over $20.
tamparacing.com
I still kinda dont understand though cause isnt the tie rod just one peice on each end then it goes the steering rack? Where is the inner tie rod and outer tie rod located?
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Here's a pic of it installed on the car. It's "outer" because the "inner" part is threaded into it. The outer tie rod end is hollow, but threaded so it can recieve the inner part. For adjustability of course.
o ok, now I see. Thank you for showing me those pictures. that helped alot.
No problem man
I got it here: http://www.hondapartstore.com/honda_ball_joint.html
I bought them like a month or so ago, left and right, and both lower balljoints for like $75. I think they were around $13 each OEM. I just checked though and the prices raised a bunch.
But damn when I put them on, my steering tightened up so much.
damn thats about what my bushings look like (from your old tie rod). now when adjusted does this toe?
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
