intercooler question
Here's goes my 160 dollar ghetto intercooler setup.
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
well if its a T25, you cant crank the boost up... if you are seeing only 7-8 psi at the manifold, that means you could be running 10-11 psi at the turbo compressor discharge... if you crank it up so you see 10-11 at the manifold, you could be puttin out 13-14psi. at that pressure, your shizzle is gettin pretty hot...
what size turbo are you runnin anyways?
but yea, hes right, a big FMIC on a litle turbo is "like you trying to pressurize a cave by just blowing into it"..
its a non turbo to turbo cionversion and it has a hahn racing super 16 on it i belive. stage 2 kit from hahn. good luck adam
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
Originally posted by psifactor
what makes it so super? is it ball bearing?
on a 16g wheel, you can do very well at 14psi, but anything over that is puttin out more heat than its worth.
Oh yeah and I ran it like that for 2 years and probably over 500 races. I got rid of it to get a bigger turbo, it was still in great shape.
