turbo charger
Originally posted by Sneakin Deacon
the basics of an engine is fuel air and spark...you put more air in (nitrous, turbo, or supercharger) you need more fuel. once you start messing with that, it begins to get expensive.
The stock motor will only hold 8-10 psi anyway so the cost of additional or bigger injectors is not really an issue.
thanks yall, i will be doing a lot of reasearch but it will be well worth it in the end....ps www.2gnt.com isn't working..any other links?
