HELP Check Engine Light CODE PO 135
So I start my car and I notice the exahust note is lower and louder than usual, I rev the engine and my bov is even louder than normal, theres a more noticable vibration from the engine and slight knocking sounds. I drive to pick a friend up and then when I restart the car it happens
CHECK ENGLINE LIGHT COMES ON!
Plug it in to the scanner and code PO 135 pops up O2 sensor heater malfunction!
WTF is this I know what a 02 sensor is but what is the malfunction what could have caused it and how can I fix it?
HELP DSMers
HELP DSMers
if you 02 sensor was bad, it would probably just sit in one spot at all times
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
I dont have stock exhaust. My TPS was bad so I replaced that and the CEL went off. Then I got in the car the next morning and the CEL came back on. I took it to Autozone and they hooked up the computer and it gave me PO135
