Adjusting clutch
Old 05-02-2004 | 06:15 PM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Default Adjusting clutch
My clutch slipped like down on the pedal or some shit i cant explain it. But can you adjust the pedal???
Because its so low that i cant engage/disengage the clutch. Its getting the point where i cant put the car into gear. At all... So im sitting at a green light trying to put it in gear and people are honking and there is nothing i can do about it. Help!!
Old 05-02-2004 | 06:34 PM
Tdman3627's Avatar
Aaron i had that same problem. It resulted in my clutch blowing out. Hopefully its something different with you. WHen you say your pedal is low, is it sticking to the floor?
Tengo un slow GST
Old 05-02-2004 | 07:15 PM
no.
Old 05-02-2004 | 07:43 PM
97TSI's Avatar
Jewbling
there should be a bolt(s) near the bottom of the clutch loosen them up and pull the pedal up then tighten the bolts...if the pedal still sticks replace the clutch
.02 cents
Good morning Hebrews and Shebrews ...wut a glorious jewish day...lots of coupons in the sunday paper eh, lots of good deals there...so i went into the store to buy a T.V. and they wanted $800 bucks for it so i "ussed" them down to $500
~Peter Griffin
Old 05-02-2004 | 07:51 PM
It doesnt stick to the floor its just i have to push it to the floor to get it to disengage, but it still is not all the way disengaging. Can you adjust a hydraulic clutch? or just where the pedal hits?
Old 05-02-2004 | 08:02 PM
Mr 2's Avatar
New Member
yeah, the master cylinder rod to the clutch pedal is adjustable.
Old 05-02-2004 | 08:18 PM
str33tracer_18's Avatar
check your clutch fluid. does pupming the clutch pedal help?
Old 05-03-2004 | 03:56 AM
Negative on the pumping of the clutch. Its just like too low i cant explain it. So bgy adjusting the rod on the master cylinder it should raise the clutch and stuff?
Old 05-03-2004 | 10:58 AM
97TSI's Avatar
Jewbling
when you adjust the pedal there should be .2-.5 inches of freeplay before resistance from the clutch is felt
right from the owners manual
Old 05-03-2004 | 11:34 AM
psifactor's Avatar
Hello
Maybe the slave cylinder is going bad. They usually will before the master goes.
Just stick your finger in the rubber boot and see if you feel fluid. If you can feel fluid its probably slowly leaking it out.
It does not sound like an adjustment if it just suddenly changed.
Heavy car with a 2.5L
