fuel trim malfunction bank 1
Old 08-04-2004 | 07:02 AM
boosteddsm's Avatar
Awd the enemy of fwd
Default fuel trim malfunction bank 1
Does anybody have any idea to correct this problem? I went to mitisubishi and looked it up in the service book gave me a few different options on what it could be, such as exhaust leak, maf sensor,intake mani leak, etc. Just wondering if anyone else has had this code thrown at them before,
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old 08-04-2004 | 07:07 AM
Ian MMF's Avatar
Omnipotence
From yoru other post talking about trying to get the exhaust manifold off I'm guessing you didnt get it off and now your throwing that code from trying to get it off.
Old 08-04-2004 | 07:11 AM
boosteddsm's Avatar
I ve been throwing that code for awhile, tony at sidewinders said that i had a warped mani, so i figured that might be throwing the code. Thats why im trying to change them out.
Old 08-04-2004 | 07:26 AM
Ian MMF's Avatar
Omnipotence
If you have a warped exhaust manifold what are you replacing it with? What are you doing with your old one?
Old 08-04-2004 | 08:30 AM
boosteddsm's Avatar
nothin why? Do you want it? If you do i ll trade it to you for the power steering p[ump we talked about that you got.
Old 08-04-2004 | 09:05 AM
Ian MMF's Avatar
Omnipotence
Works for me, I'll find it in my garage this weekend and bring it with me to tampa sunday.
Old 08-04-2004 | 09:09 AM
boosteddsm's Avatar
cool hopefully ill have this damn mani off. Ill have to try that pb blaster and hope that the weather cooperates with me
Old 08-04-2004 | 09:20 AM
Ian MMF's Avatar
Omnipotence
The pb blaster stuff is the shit. Redlinegvr4 was on the right idea with letting the car run. It would have the same effect as if you were trying to take the 4 turbo bolts off and you took a torche to them. I would definitally go the pb blaster route though, should work just fine.
Old 08-04-2004 | 05:11 PM
TampaTSi's Avatar
ever changed your o2 sensor?
you have a k&n filter or a stock air box. if stock, have you changed the air filter recently?
sidewinder cracks me up. it's not your exhaust mani. you'd know if you had an exhaust leak...it would smell like exhaust.
do a leakdown test to see if you're leaking out of the intake mani. if you don't know how, www.vfaq.com.
1998 Eclipse GST
Old 08-05-2004 | 06:03 AM
Sneakin Deacon's Avatar
PSSHHH x2
if your manifold is leaking prior to the o2 sensor it can cause that as it sees a very lean reading. if its after the o2 sensor, its more then likely something else.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
