crank pulley (broke) need new one
Originally posted by Jordan Y.
Here, this one thread will do: http://tinyurl.com/3kwmn
I don't like linking to that board, but there's no other way of backing up what I said.
Summary: Buschur, John Shepherd, and Marco at Magnus have good reasons for running a dampened pulley. That's good enough for me.
That's fair enough. That is, if you're going to make a conclusion about UR crank pulleys, you need to have valid premises to support that conclusion. However, if there is a remote correlation (and of course, that is not to say that correlation means "x" causes "y") then is it worth the risk? Why save $50 on a pulley that may cause engine failure? Is a marginal power gain worth it and $50 worth engine failure? I'm not debating whether marginal gain is worth the risk (everyone takes that risk for gains, but I don't know anyone that installs parts KNOWN to cause engine failure), but is it worth it when there's the more expensive alternative and the risk is eliminated? Not to mention, I don't believe that "gain" is even proven. I wouldn't install a UR crank pulley.
EDIT: Would you install an air filter that's suspected to filter horribly, but allow more flow, in order to save $10?
One question that does arise though, how come only one company offers a dampened pulley? I'm sure these manufacturers put alot of money into R&D....if there was a chance that this was truly a valid claim, don't you think these manufacturers would make the proper pully in order to uphold customer satisfaction, not to mention draw a greater profit?
