convertible top question
Old 01-17-2005 | 08:14 AM
Lay Maha's Avatar
Jaded Mitsu
Default convertible top question
My top will not open. When I press the switch the windows come down and I can hear a click. I think I checked the fuse and everything seems to be okay. I don't know where the relays are for the convertible top?
Old 01-17-2005 | 09:20 AM
Chris LS's Avatar
just blaze...
It's probably the motors that control the movement. Mine went out as well when I had it, everytime I had to open and close it manually. I believe the motors might cost (used) $130 each. But check the fuses first.
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old 01-18-2005 | 12:22 AM
TBSpyder's Avatar
Alot of times it's just the pin in the motors. Might wanna pull it apart and take a look...if so I've read a way to fix it using a piece of metal coat hanger.
