Turbo ?
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
all depends on what kind of turbo you want to run i put a turbo setup on my friends dodge avenger in 3 days run great other then fuel cut off if your really serious ill tell you how to do it.
SVT F150
SVT F150
ok first off you need a welder, or know some one who has one. you can use your stock exhaust manifold step one cut off your exhaust flange off of the down pipe next get a peice of 20 gauge steel and either bolt it or weld it to the top of the turbo then you need to weld the exhaust flange you cut off to to the steel that will bolt up right to your manifold. make sure you put the turbo up as close as you can to the manifold. the next step your going to get a peice of exhaust pipe and weld it to your down pipe connect it back to the exhaust and your exhaust system is done. now you need to take your oil pan down and drill a hole in it for the return line make it high enough so it will return smooth. your oil pressure swith is in the back of the moter you know need to take that out and get the brass fittings to go into the block and run your oil feed line. then you just need to hook up your piping and your blow off can go to one of your nice sized vacuum lines you also need to make a missing link for your map sensor just raise it above the intake manifold nad you should be good. your going to need to get a bigger fuel pump and the injectors you know and the rest of your stuff and you should be good.
SVT F150
SVT F150
