supercharged 3g almost done
Old 05-17-2005 | 10:16 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
Default supercharged 3g almost done
been helpin my friend install a supercharger, just waiting on some electrical components and an oil line.
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old 05-17-2005 | 10:18 PM
goat's Avatar
holy shit. gfg
Old 05-17-2005 | 10:19 PM
what's up with your car goat?
Russ
03 Infiniti G35
01 Lexus IS 300
Old 05-17-2005 | 11:37 PM
LS1Fever's Avatar
russell, whats up with your car?
Old 05-18-2005 | 06:25 AM
MightyMaxGS-T's Avatar
Hey Russell we've been building a lot of nasty DSM's lately...lol
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old 05-18-2005 | 08:39 AM
need a new driver's side cv joint, map sensor, and tuning. should be done after that, but most likely ill run into another problem. can't wait to see chris's ish back up tho
Russ
03 Infiniti G35
01 Lexus IS 300
Old 05-18-2005 | 09:45 AM
TooN's Avatar
Supercharged
Supercharger Install is all hung up on the oil feed fitting for the supercharger. It was broken off in shipping. Hoping tomorrow it comes in along with a dial trimmer for the methonal boost cooler. break-in is a 5psi pully then once the methonal is working i'll install the 9psi pully.
Charlie
Supercharged 2000 V6 Eclipse
Ferktech:I love Bert's constant DSM abuse pictures. Apexi crankwalk controller is set to 68% while the main bearing damage indicator is tuned to a near perfect 42%. Chances of DSM survival, close to zero. Thank god you've got a V6 Mopar GT with aluminum can pistons which break off in chunks and destroy valves. Showed those 4 cylinder boys how to fuck up an engine the right way. Crankwalk pish posh, we fling high speed metal parts here!
Old 05-18-2005 | 10:20 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Whats the specs on that...is it a kit for those? What kind of power are you going to be looking at after the 9lb pulley.
SUCH IS THE RULE OF HONOUR.
Old 05-18-2005 | 10:41 AM
toon, correct me if i'm worng, but after we pistons and rods, he sould be looking at 410-420 at the crank. its a rippedmods vortech supercharger kit.
Russ
03 Infiniti G35
01 Lexus IS 300
Old 05-18-2005 | 11:18 AM
Thats pretty nice if your able to get those numbers, i didnt even know they made superchagers for those cheese balls.
