idle surge problem
Old 05-24-2005 | 04:17 PM
  #21 (permalink)
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Have you tested the ISC? Or what about the pcv valve, sounds stupid, but ive seen it work...how much is vacuum at idle, where does it idle around.
SUCH IS THE RULE OF HONOUR.
Old 05-24-2005 | 04:21 PM
  #22 (permalink)
Philly Blunt's Avatar
TR Balla Donor Supreme
the isc was good and the pcv valve is good not sure on vacuum yet because autometer gauge isnt on yet tomm i will hook it up
Old 05-24-2005 | 10:11 PM
  #23 (permalink)
it idles around 1100-1500 surging and sometimes it stalls
Old 05-24-2005 | 10:17 PM
  #24 (permalink)
i just thought of something ive looked at all the aftermarket turbo intakes and they all have the stock desingn w/ the curve i have a custom 2.5 inch straight intake pipe would that cause a problem?
Old 05-25-2005 | 08:21 AM
  #25 (permalink)
25psi's Avatar
Treated and Released
Try cleaning the TB, I've heard if to much carbon builds up on it it can cause idle issues.
*Edit*
Whoops he already did that.
-Jim
“Equality, rightly understood as our founding fathers understood it, leads to liberty and to the emancipation of creative differences; wrongly understood, as it has been so tragically in our time, it leads first to conformity and then to despotism”-Barry Goldwater
Old 05-25-2005 | 08:27 AM
  #26 (permalink)
russellbeermann's Avatar
F*ck da rent, get the Lex
i am currently having the same problem on my 2g. i ran an obd2 scan and it said i had a bad map sensor. i don't know if this would apply to you tho
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old 05-25-2005 | 11:52 AM
  #27 (permalink)
well i do have a datalogger and palm pilot i wish i knew how to use it im just gonna plug it in and see what happens
Old 05-26-2005 | 01:56 PM
  #28 (permalink)
any more ideas?
Old 05-26-2005 | 01:59 PM
  #29 (permalink)
25psi's Avatar
Reset the ECU?
-Jim
Old 05-26-2005 | 02:23 PM
  #30 (permalink)
have you hooked up a boost guage yet, to check what vaccum your running
