idle surge problem
Old 05-21-2005 | 04:15 PM
TTalon's Avatar
Default idle surge problem
my car has an idle surge here are the things ive done
new biss o ring
egr block off
new gaskets
idle air control valve replaced
throttle body cleaned
checked for vacum leaks none
it still surges even after doing this but when a/c is on it doesnot surge for about 20 minutes weve tried everything we thought of any help is good thanks and the car is basicaly stock
Old 05-21-2005 | 04:20 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Check your ecu....what kind do you have in there?
SUCH IS THE RULE OF HONOUR.
Old 05-21-2005 | 04:40 PM
TTalon's Avatar
stock ecu should i reset it?
Old 05-21-2005 | 04:41 PM
dsmtuner's Avatar
gotta love the boost
thats what i was afraid of we will just have to see if it gets any worse.
SVT F150
Old 05-21-2005 | 04:46 PM
TTalon's Avatar
by the way the car is a 91 fwd turbo
Old 05-21-2005 | 04:56 PM
http://vfaq.com/mods/BISS-1G.html
did you do anything along these lines? and if so, you may want to switch out your ecu with one from a working car, ive went thru so many different things about my surge, while the whole time it was my ecu.
Old 05-21-2005 | 06:23 PM
91TSI_AWD's Avatar
Resident Galant Guy
do you have coolant going into your TB? or has that been bypassed?
If its been bypassed, block off your FIAV
Mike
95 Lancer GSR
93 300ZX 2+2
Old 05-21-2005 | 06:43 PM
Thats a good one I forgot about.
Old 05-21-2005 | 07:55 PM
BoosTb4BroaDs's Avatar
isc
Old 05-21-2005 | 09:32 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
is there any link on how to do this? because there is no coolant on the throttle body and i did not take it off so i would like a link on what to check for
