Someone HELP..Have HUGE problems with my car... Codes 13,14,21 and 25... Please HELP!
Old 07-23-2005 | 07:07 PM
Tribusracing's Avatar
Default Someone HELP..Have HUGE problems with my car... Codes 13,14,21 and 25... Please HELP!
I have a 92 Talon TSI, it had a check engine so I checked it today and it was a 13,14,21 and 25. I replaced the Coolant temp sensor and it is still throwing a 25. Can anyone give me any insight on what I should do??? I dont know what to do about the other codes either.... Any help would be great .. Thanks guys in advanced.
Old 07-23-2005 | 08:05 PM
Skillionaire's Avatar
Nobody
Is the car behaving any different? CEL's arent the end of the world in DSMs. Could be just a bunch of emissions BS
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old 07-23-2005 | 10:59 PM
BoostLogik's Avatar
BoostAddict
Ah, the world of having an OBD system. I wouldn't worry too much either. Like the aforementioned stated, unless your car's performance has changed drastically, I wouldn't really worry.
I bet a couple of those codes are probably along the lines of fouled O2 sensor, charcoal canister full, etc.
"Even through the darkest days, this fire burns, always"
Old 07-24-2005 | 05:53 AM
hunntyr's Avatar
After you changed the parts, did you reset the ecu???
Old 07-24-2005 | 11:15 AM
Mr 2's Avatar
New Member
Most OBDI codes are 3 digit numbers maybe the 2 digit numbers are OEM specific.
http://kenellison.com/odb.html
http://www.honda-tech.com/zerothread?id=1171263&page=1
Old 07-24-2005 | 06:06 PM
mikeyees13's Avatar
now with more protein
dissconnect the battery and reset the computer.
Old 07-24-2005 | 08:11 PM
The car take abour 2 mins to start in the morning.... after cranking and cranking......
the car bogs and spuders...... the car does not go anywhere when the car from 2k up is boosting 14 and does not go down until I let off the gas....
Old 07-24-2005 | 08:20 PM
NightRdnEclipse's Avatar
Ralfy
If you mean it hits the revlimit at around 2-3k RPM it could be that your TPS unplugged itself, my other 2 Eclipses tended to do that when I hit a pothole or something.
-Ralfy
http://www.myspace.com/ralfy4
Old 07-24-2005 | 11:28 PM
It will keep going it just is VERY sluggist from about 2k to redline...Like it has no power at ALL
Old 07-25-2005 | 08:30 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
you said you replaced the coolant sensors, but that not starting up thing and sputtering sounds like the coolant sensors.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
