Boost guage on EVO
Old 08-03-2005 | 02:39 PM
FiLjAr4LiFe's Avatar
www.myspace.com/filjar
Default Boost guage on EVO
Hey guys popping a boost gauge in the evo today, wondering if there was a spot where i wouldnt have to drill or poke a hole or anything like that in order to get it through to the engine. And which line to a t off for the gauge?
Thanks.
Aaron.
Old 08-03-2005 | 02:52 PM
F4A22's Avatar
Old School
Tee off the fuel pressure regulator.As far as finding a hole make one.
Old 08-03-2005 | 03:25 PM
I was told there was a spot so you don't have to drill or poke. Don't want to fuck warranty... Which one is fuel pressure regulator? I see 2 lines going into the intake manifold, one has white dashes on it the other has yellow. Looks like there is a spot for a third line but no line going in...
Old 08-03-2005 | 03:48 PM
Ian MMF's Avatar
Omnipotence
Put all your parts down slowly and step away from the evo.
Old 08-03-2005 | 05:22 PM
NightRdnEclipse's Avatar
Ralfy
-Ralfy
http://www.myspace.com/ralfy4
Old 08-03-2005 | 06:21 PM
Thanks for being so helpful.
Old 08-03-2005 | 06:28 PM
Ian MMF's Avatar
Omnipotence
T off the line going into the fpr and then run it through the hole in the fire wall where the rest of the wire goes. Then hook it into the back of the gauge and mount it. Connect the wires for the lights to the correct lights on the wiring harness so when you turn on your lights the gauge lights come on also.
You could check vfaq, it tells you how to do that there. You're not a newb so you should know stuff like this.
And youre welcome.
Old 08-04-2005 | 06:45 AM
FastEclipseGSXT's Avatar
lmao, you gotta love it
Jeremy
www.myspace.com/biggrapes01
Old 08-04-2005 | 04:35 PM
So i found a diagram of which line i should tap... It says on vfaq off of the P line. Well on the evo, the P line isnt therelol. There is just a hole.
What do i do?
Old 08-04-2005 | 04:54 PM
Ian MMF's Avatar
Omnipotence
Closest thing I found for you.
http://www.lancershop.com/customer/pages.php?pageid=14
