boost
Old 08-15-2005 | 06:03 PM
EMonzVIII's Avatar
Evolving
you can run as much boost as you want out of it but any more than 19 PSI your just blowing hot air its not going to be as efficeint as it can be. My buddies 91GSX did a 12.9 @ 18PSI the turbo lasted 50K. I have seen the 16G in the EVOs being run as high as 28PSI. these guys at 28PSI are putting down nearly 500 on the ground. with a GT35R at the same PSI they are getting better #s. only thing with them running 28 on the stock 16G they are all running the alky injection. some of the 35R guys dont even use the alky kits yet.
hey I dont know much about the 14B but Its not going to be doing what you want at really high boost levels. maybe the 1G guys need to just finish this thread
2003 Mitsubishi Lancer Evolution VIII
Old 08-15-2005 | 06:09 PM
Tom N's Avatar
Non DSM.....DSM guy
Larger turbos will always produce cooler air at the same boost level as a smaller one.
Not sure what that has to do with his question though.
You want to go fast. Run as much boost as possible and tune to it.
Tom
Old 08-15-2005 | 06:30 PM
BOOST JUNKIE's Avatar
slow
no wastegate vac line?? that is childs play.... physically wire the wg shut, like the big boys.
I would run as much boost as you possibly can with good gas and/or spray a shitload of alcohol into the motor.
And no stock turbo evo is putting down 500 on boost, lets not kid ourselves.
Old 08-15-2005 | 06:34 PM
Tom N's Avatar
Non DSM.....DSM guy
Never wired one but have been known to shim them abit.
Tom
Old 08-15-2005 | 06:47 PM
GsEclipse02's Avatar
open waste gate how much boost does that produce?
Old 08-15-2005 | 07:06 PM
Tom N's Avatar
Non DSM.....DSM guy
To many variables to answer that.
Tom
Old 08-16-2005 | 03:22 AM
  #17 (permalink)
EMonzVIII's Avatar
Evolving
There are a few nearing that mark but like I said i wasnot stock it was running 28PSI on the stock turbo with supporting mods. Ther are only a hand full of evos that even run the stock 16G that high. The stock 16G at 22PSI has made over 400WHP on the EVO a bunch of times.
Old 08-16-2005 | 03:46 AM
  #18 (permalink)
The Spectacle's Avatar
Spent more money than you
Originally Posted by TRIPLE G
If you guys ever wont to make some power then stop beeing scared of boost. 14b`s are a dime a dozen, run it wide open till it blows.
I cannot stop laughing. I love you DSM owners.
Racing Integration
LHT Performance
My tuner is named Alpha
Old 08-16-2005 | 04:18 AM
  #19 (permalink)
F4A22's Avatar
Old School
Mine has creeped up to almost 30 lbs before and still doesnt smoke or have crazy shaftplay.Like tom said quite being pansies and up the boost if the fuel is there.Its only a 14b.
Old 08-16-2005 | 05:01 AM
  #20 (permalink)
Ian MMF's Avatar
Omnipotence
There is NO one making close close to 500whp on the stock evo turbo without nitrous. And the evo does nto make over 400whp at only 22spi. Take your head out of your ass man, we aren't dsmt00ners.
