Please help. Im baffled.
Originally Posted by TRIPLE G
Dont feal bad. I generaly go and replace all that stuff anyways. Thats why my cars never break. They have all new parts on them.
Originally Posted by Ender.
Could anyone else elaborate on this?
If the prportioning valve doesnt fix it, Im thinking along the lines of transfer case or something but its still weird because I thought the transfer case was front to back and not side to side, well see...
There's a hard plastic one-way check valve in the line from the intake manifold to the brake master cylinder. If it's not there you can blow out the seals in the brake master cylider, then it's kaput, needs replacement.
Here's something to check- are those original brake lines? I've heard of old rubber lines rotting and actually having flaps rot away inside so that when you press the brakes it locks pressure in the line which slowly seeps away. Something to check before you throw more parts at it.
Also, very sorry about the edit. I'm tired and not familiar with the new mod buttons, and I thought I hit "quote" . I put the post back to the way it was, minus my comments .
Ill be sure to look in to the lines. If the master doesnt fix it or the proportioning valve I guess Ill be moving on to SS lines next. Oh well at least I wont have to worry about the brakes for a while!
Im replacing the master cylinder tonight. Ill let you know how it went in a few hours...
Make sure you bleed the cylinder also.
Did I already fuck something up from not bleeding the cylinder to start? or is there still hope...
