overheating 2g rs-t
Old 11-25-2005 | 07:53 AM
mitsu420aT's Avatar
Angry overheating 2g rs-t
i have replaced the thermostat 2wice and the radiator has been back flushed. it only gets hot when i start to build boost and then when i drive normaly again it go back to normal.any other boosted 420a have this problem or heard of it. up for suggestions!?!?!
Old 11-25-2005 | 09:15 AM
hunntyr's Avatar
Check your ECT switch (engine coolant Temp). its a little switch right underneath the thermostat housing. It might be corroded and throwing the sensor off. I replaced mine in my boosted 420A and that solved the overheating issue. Also check for cracks in the housing itself where any leaking could be spotted.
Old 11-25-2005 | 09:58 AM
mitsu420aT's Avatar
thanks for the info, i have indeed looked for any cracks in the housing there a re none due to the fact that i have just put a new one on because i broke the original one while changing the org thermostat.i will change the switch again due to the fact that some times you get bad ones.
Old 11-25-2005 | 10:05 AM
elitist's Avatar
TR Balla Donor Supreme
Lol I had an overheating problem last night... my radiator cap blew off while I was driving LOL it was kinda funny although I had to get a cop to give me a ride home lol. You do have an intercooler though right... it's not hot piped is it?
Old 11-25-2005 | 10:13 AM
mitsu420aT's Avatar
i do have a inetrcooler but i was hot piped for a while. i still have the problem but not as bad as it was while hot piped
Old 11-25-2005 | 10:31 AM
elitist's Avatar
um well if you heat wrap the intercooler piping it will trap that cool air... that'll make it run a little cooler although it won't look that good.
Old 11-27-2005 | 06:15 PM
GsEclipse02's Avatar
or ceramic coat it ...looks and does a better job...
