Cyclone intake manifold
Originally Posted by imdeadsexy
[IMG]
Now lets see if this will let me hit boost in first gear.
i know this was for me ...
ill be playing in a car soon
and we will both be walking all over dario !!!!!!
WTF is this team up on Dario day???
Fuck you all John has my back dont you hunny hook it up so I can stomp on these little fools.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
-Dario
Just out of curiosity, are those things capable of producing a nice gain?
I've read that you need to have all the electronics to actuate the butterfly valves. Does it fit on the 2G's relatively well? I've read that the A/C on our cars is usually an issue in fitting these in. Would we be able to keep the A/C and still use this?
I noticed the Brothers run one of these also. I'm just wondering if it's worth it to install this.
Also, how much do they usually cost?
Originally Posted by LS1Fever
Hook it up how? I got your back but damn, how much you want from a cracker? I only have so much to go around.
john love's the cock
Originally Posted by boosteddsm
What you think your gonna be fast now.
looks like he has a leash on it
taking the manifold out for a walk since you cant take your crank???
ps just realize that you will never beat the silver bullet... youll make your life a whole lot easier
As for the butterfly’s jerry has invented the “t-25 mod”instead of using the electronics to active the butterfly’s he has adapted an actuator form a t-25 turbo to opens the butterflies at 8 or 9 psi.
The a/c can stay in you just have to grind a part on the manifold in order for it to fit.
Is it worth it? Ill post up some logs to show the before and after affect.
And you can find this thing on ebay for 100 bucks.
Juan
this just in,
You suck!
Jesus that was long....
John all I meant was that you were going to have Jerry order my "stuff"
Juan I'm ready whenever you are ill even run you in my current boost leak state. 17psi baby
Boostlogik - forgot your name sorry.
Juan is correct for the most part but on 2g the ac compressor is not an issue its only 1g that have that problem and it is due to some dumb ass hump in the 1g ac compressor.
-Dario
-Dario
Form what ive been reading is that it helps the midrange of the power band but the top end is affected just a little and it will decreases spool up time in the power band any ware form 200-800 rpm sooner.
Juan
Juan
Then again, I'm still on the stock T-25, so I wouldn't know what anything past 130 would feel like. I'm sure the guys running the larger compressors could vouch for having much better top end pull.
BTW Dario, no problem about forgetting my name. I know we've never formally met in person, only talked a couple of times via PM. My name's Ron though, just so you know.
