Slugggish 92 TSI
Old 05-12-2006 | 07:37 AM
fredricow's Avatar
No SAFC or FPR.
Old 05-12-2006 | 08:11 AM
Skillionaire's Avatar
Nobody
Originally Posted by Sexpert
How is cooling cousing this? are you serious? Not to be rude here but coolant would be the last thing, if it was coolant related, the engine would have blown a headgasket since he's WOT it all the time obviously to check it out, the smoke wouldnt be Black, which 90% of the time is because of running rich, the smoke would be white due to all of the coolant/oil mixture. Its obvious that he is having air induction problems.
is the engine acting normal? is it bogging? any other symptoms?
Sexpert.
Actually, although unlikely, the coolant temp sensor could potentially cause the problem. If this sensor isnt working properly, the car will run in safe mode which in turn will make it feel like ass.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old 05-12-2006 | 09:09 AM
Sexpert's Avatar
Safe mode will not do this. But hey, its worth the try, its better just to be clear and out of doubt, check the sensor.
Diamond Star Motor..IST
