losing patience with eclipse
Your coolant temperature sensor being bad will cause your car not to run or even start properly. I've had the same problem and I had to replace the sensor. It's really easy to do as long as the car is cold, and oh yeah make sure you got some rags handy it can get real messy. I hope this answers your question.
yea that definetely helps my question...im most likely getting the sensor wednesday and replacing it by the weekend. BUT the thing is the car has been running funny before that as far as the motor knocking and RPM surging when car is cold from 800-1200 rpm...the check engine light sensor just started saturday after replacing radiator and removing thermostat, so i can see how replacing the sensor would solve the starting rough or stalling part of it. hope for the best..
does anyone know what the hell the "pressure switch connector" located on the power steering pump does.. i just replaced my pump a few weeks ago, and on the old pump the connector was never there guess it was broken, and its not connected on the new one B/C the wire connector end is loose..Also would this connector be in anyway connected with the A/C system??
