ideas for starter problem?
Old 01-02-2007 | 02:29 PM
  #21 (permalink)
boosteddsm's Avatar
Awd the enemy of fwd
Originally Posted by lancerman
tap into the small wire on the starter. run a wire from there to the ignition switch harness. connect to the black/white stripe wire. this is a very common problem.
Dane this is similiar to what I was saying, in the other post.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old 01-02-2007 | 02:41 PM
  #22 (permalink)
95GST's Avatar
boost is your friend
check the main fuse in the fuse box that is in the engine bay its a 100 amp fuse and bolts in
Old 01-02-2007 | 02:58 PM
  #23 (permalink)
GNEn!st's Avatar
AWD all the way
Originally Posted by Usuck!
check ur battery, to make sure the pos. cable is connected ALL THE WAY or check ur batter lines too only thing i can think of
my girls car had the same prob and the battery lines were loose thats what was causing it
Old 01-02-2007 | 03:04 PM
  #24 (permalink)
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
im sure hes checked the cables already.
having to rewire the starter is not uncommon at all.
SUCH IS THE RULE OF HONOUR.
Old 01-02-2007 | 05:06 PM
  #25 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok, ive never looked at the ignition switch harness but is it right on the ignition module itsself? if not where is it located?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 01-02-2007 | 05:15 PM
  #26 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok i think i found it.....is it the wire on the blue clip on the back of the ignition switch?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 01-02-2007 | 08:27 PM
  #27 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok whatever, i just took an ignition wire, tapped into it, and wired it to a switch that turns the starter on. problem solved, car turns on im happy haha.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 01-02-2007 | 08:30 PM
  #28 (permalink)
Tom N's Avatar
Non DSM.....DSM guy
Good Job.
Tom
