My Eclipse Keeps Stalling Please Help
I Own A 96 Eclipse Gs 2.0 It Keeps Stalling Out On Me. I Have Pulled A Dtc 43 Or Po135 Out Of The Ecu Ignition Coil Circuit Failure. I Have Replaced The Cam Sensor The Crank Sensor And The Ignition Coil And It Still Does The Same Thing. It Has Plenty Of Fuel Pressure When Stalled. It Just Has No Spark. Sometimes When It Stalls Out It Will Start Right Back Up And Be Fine With No Check Engine Light. Other Times The Car Has To Sit For A Couple Of Hours For It To Start Back Up. Any Help With This Problem Will Be Greatly Appreciated. Thanks
mine is doing the same thing... mine is a forward 02 sensor but my check engine light is on too so it may not be the same thing... get ahold of an obd2 checker and plug it in if your in tampa or lakeland i can get ahold of one for u if you need anything else hit me up at 813 217 3022 my name is TJ
i had the same problem with my 95 rs back in the day...it ended up being a bad cam sensor that needed replacing....but i see you've already done that so idk what to tell you... ::shrugs::
and now introducing my newest toy...
-Silver Slow-poke-
i have scanned it with an obd2 scanner and thats when i got the po135 code from it. the cam sensor and the crank sensor have been replaced but they are aftermarket parts from auto zone and dont know if they are junk parts. if any body has these parts oem let me know. thanks for your help.
i would recommend taking ur car to ramtech on armenia ave...they know everything when it comes to chyrsler/dodge motors...they fixed my 420a
-Silver Slow-poke-
if your asd relay is shot it will throw cam and crank sensor codes. The asd relay is what supplies 12v power to your ignition coil. Try jumping 12v power to the center wire on your ignition coil and have a friend try to start the vehicle. If it starts its your asd relay
