help me out here
Old 09-17-2007 | 05:46 PM
DSMJeff's Avatar
Fuckin' Lingerer
then what can it be???
Old 09-17-2007 | 05:50 PM
DSMJeff's Avatar
Fuckin' Lingerer
what can explain nothing coming on when I click the ignition twice, only my radio and air comes on???? I have to sit there and turn the key back and forth till the lights on the dash comes on until I can start the car.
Old 09-17-2007 | 08:17 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
you may want to start by taking apart the steering column and checking voltage at the ignition module to make sure the ignition isnt going bad.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 09-18-2007 | 01:06 AM
omgosh's Avatar
Is the starter actually turning the engine over? Or is it just making a click noise every time you turn the key?
Sounds like it could be some loose wiring, or possibly the starter going bad. Put it in reverse and rock the car back and forth a bit when its not starting. If it starts after that, could be a bad starter. People do sort of the same thing by tapping it with a hammer and then trying to start it.
Old 09-18-2007 | 02:46 AM
DSMJeff's Avatar
Fuckin' Lingerer
yeah when i do turn the key it tries to turn the engine over. Also this morning everything started fine, but, car started and it was on for like at lease 10 secs and shut off, but everything else was still on??? cranked it back upagain and it was fine after that??? Idk what it might be?
Old 09-18-2007 | 04:36 AM
Dario99gst's Avatar
Tu Papi Chulo
I had a similar problem when I had a 95 basically it was a the terminals they were corroded and had a loose connection.
I would go to discount get one of those battery terminal cleaner things (like 3 bucks) and clean off both the terminal and the battery. Then tighten the shit out of them.
You also want to check your ground. Sometimes it comes loose from the firewall.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old 09-18-2007 | 05:04 AM
  #17 (permalink)
DSMJeff's Avatar
Fuckin' Lingerer
^^^ yeah my terminals are pretty bad looking,I will stop by and pick up the cleaner today. But what will explain the car shutting off after 10 secs running? But I do have a feeling it has something to do with the battery.
Old 09-18-2007 | 07:24 AM
  #18 (permalink)
Tom N's Avatar
Non DSM.....DSM guy
As long as your alt is working once the car is running you can disconnect the battery and the car should stay running.
Tom
Old 09-18-2007 | 11:20 AM
  #19 (permalink)
DSMJeff's Avatar
Fuckin' Lingerer
Today i was driving to work and when I was in low 3nd gear the car cutted off for like 2 seconds and then turned right back on. Idk I think it might be my alternater. If i turn on my car and disconnect the battrey the car should keep running right? If i disconnect the battery and the car shuts off the alt is bad right???
Old 09-18-2007 | 02:05 PM
  #20 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
make sure you have a ground from your firewall to the intake manifold. my car couldnt stay running if i disconnected the battery, and the car would just overall act really funny.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
