Pics of my setup
Old 12-12-2007 | 06:17 AM
Black_Bullet's Avatar
**Dont disturb,Sleeping**
Originally Posted by Dain
Well, like I said, I am probably going to get one of those SBR shields since they are fairly inexpensive Been thinking of something to help those IATs out though for sure. Eventually I am going to ditch the body kit and all that shit for OEM stuff. I know people have been using their passenger side fog light hole to start as a duct for air routed to the intake. A/F ratio gauge stays...like I said...just something to fill the hole that was like 25 bucks haha.
Definitely see what you can come up with on that buzzer if you don't mind. I will be on like 20psi for a little while so I am not TOO worried about destruction, not saying that it won't happen
One thing I am dead set on is getting an Evo8 ecu in my car though. Just a project on the side I want to do and I know it can be done
Or you could just get a 2pillar pod instead of three
As far as thr IAT's, I did my cold air intake recently.
In case you were interested, go to home depo motorsports, pick up a 4x3" pvc pipe with a 90* bend. It will cost you like 7 bucks. Cut out the metal that sits right under the filter ( fairly easy to cut and once youve got it going you can even bend it out the way.)
Connect THE 4in side of the pvc pipe to your mas adaptor, and then connect the 3in side to your filter. Depending your intercooler routing you may have to manipulate things into place but it will work. Just make sure you have everything connected good so the filter doesnt fall off when your driving, happened to me once and rolled under my tire lol.
The broke person I am, I found a way to reuse the filter temporarily by bending it back into shape and stuff lol.
Well keep in mind about rain, i am going to make a splash shield and what not, and dont hit any puddles or boost when its raining, but other than that its a great mod... Theres been reports of people dropping 30 degs with just removing their right head light housing in front of the intake,
REMOVE your headlights at the track -20*F drop - DSM Forums
therefore I know this will gain even more since your putting the filter completley out of the hot engine bay... Expect 40deg temp drops, you will notice the difference...
Also to add, for those of us running smaller turbos ( i.e. 16gs etc )
This gain will benefit more as densor air getting drawn in will allow for more overall air to be compressed post intercooler, therefore more air flow especially in higher rpm/ pressure ratios. That would explain why i gained a 2psi spike after the cold air intake with changing nothing else !!!
Ill pm you pics of my cold air intake set up if your interested.
Officially Dsmless...
"America remains one nation, under drugs, indivisible, with perceived liberty and sickness for all." - Shane Ellison
Old 12-12-2007 | 07:10 AM
Dain's Avatar
Pics...sure! You can never learn too much haha. My buddy did this on his 1G and he was telling me all about it
Old 12-12-2007 | 07:39 AM
THE_ONE's Avatar
*Turbo Interceptor*
Originally Posted by Jap
Get ready for random Misfire !
IF he gets that he can pm me and I will get rid of it for him
Old 12-12-2007 | 10:20 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
about the CAI, i was thinking of cutting out the highbeam in the headlight, putting a pipe through the headlight, and putting a peice or metal after the light to point toward the air filter. there are also those side vents on the bumpers that you can run some pipe or dryer ducting to your filter from.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 12-12-2007 | 10:23 AM
like this
Old 12-12-2007 | 10:29 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
yea, just like that. what did they use there? i want to do that because i never use my high beams.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old 12-12-2007 | 10:41 AM
  #17 (permalink)
Yea I dont know exactly what it involves in doing it, I thought of something like that but am too lazy to do the effort. Id get a spare head light from the junkyard if your going to attempt just in case...
I still think my cai is more effective due to placing it out of the engine bay. All I used was this
and then cut out this
which put the filter here
Sorry about the size...
And one more thing, i paint the pvc pipe black so it doesnt look that bad actually...
Old 12-12-2007 | 10:46 AM
  #18 (permalink)
Ink's Avatar
Ink
Changes names a lot.
can someone please explain to me the difference in a 6 bolt and 7 bolt? other than the 7 being unreliable and having rodknock (from what i hear).
Old 12-12-2007 | 11:08 AM
  #19 (permalink)
6bolt has thicker rods, can handle more stress.
It Isnt prone to crank walk like the 7bolt....
Has different sized head ports and bigger intake manifold/ tb.
6bolt came on 89-92 1g Dsms. 7bolt stated late yr 92 up.
Rod knock has nothing to do with engine design or build... Rod knock means
the engine is damaged due to poor octane/fuel/ poor tune, leading to detonation
or from running improper oils/ or from not having any oil at all and running the engine dry or with low oil pressure...
Old 12-18-2007 | 02:31 PM
  #20 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
lol heres something i made up with what i had laying around. i think the piping is too small though, i will probably get some 2.5 inch dyer tubing and put that in. i used hot glue to seal it
-Dane
98 240 w/ bolt-ons
Srqspeed.com
