Need help with 4G64 SOHC motor misfire
its a 94 mitsu galant that has new distributor, cap, rotor, plugs, wires and the injectors are working. runs like on 3 cylinders (2 cylinder from distibutor is not working) all cylinders are getting spark and fuel.. when car is running you can pull the plug wire for the one that isnt working and the car dont die but if you pull any others it does die.. and if you swap wires from a working cylinder to the dead one it still doesn't change....
can anyone help me please this is my daily driver to work??????????
could this be a hole in the cylinder or what do you think please help
