A/C and Coolant temp sensor same part? 1Ga
Old 09-29-2008 | 07:39 AM
Neesan's Avatar
EL RIPPO
Default A/C and Coolant temp sensor same part? 1Ga
I wanted to swap out my old ECU temp sensor (on thermostat housing on left), all I have is an extra a/c temp sensor (taps into water neck). They look identical, and when searching for the parts on the napa site, they dont list an A/C temp sensor, just 2 different "coolant temp sensor". I understand the A/C sensor shuts off the air when if the car overheats, so Im guessing this sensor will read a lot higher and could be a NO NO? Im lost, electronically retarded, stupid, ignorant...you get the picture.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old 09-29-2008 | 09:52 AM
boosteddsm's Avatar
Awd the enemy of fwd
It not a a/c sensor... Both are coolant. One of them that has one wire running to it is for the gauge in the car. The other with 2 wires (at least on a 2g) is also a coolant temp. This one translates the coolant temp to the ecu. Its important to have that one on due to the ecu helping the car out with warmup enrichments etc.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old 09-29-2008 | 02:25 PM
Neesan's Avatar
EL RIPPO
On my 1G there is the single wire sensor (gauge) and right next to it on the left is the coolant sensor with 2 wires. These are both on the thermostat housing. THEN, on the coolant water neck there is another sensor with 2 wires that looks just like the coolant sensor, but it is to turn the A/C off if the car starts overheating. That is the one I was wondering was interchangeable. So I dont know about your 2G, but I have 3 sensors on mine.
Old 10-01-2008 | 04:34 PM
boosteddsm's Avatar
No not on the 2g's. We only have the 2.
Old 10-04-2008 | 11:02 AM
Neesan's Avatar
EL RIPPO
Nobody knows? Am I the only 1G with 3 sensors on the T-stat housing, like some kind of freak?
