Did I make a opps?
Old 10-11-2008 | 12:17 PM
Todd's90's Avatar
0711, USMC
Default Did I make a opps?
I did some searching around and found that ARP thread lock is supposed to be used with the studs, also I only torqued mine to 80ft pounts because thats what I read on vfaq but ARP's site recommends much higher when using oil and not threadlock. Is it possible and should I take the valve cover off and either torque them down higher or take them out one at a time and use thread locker? the car runs great now but I don't want it to be something I need to worry about.
1990 GS-T
1990 GST
2004 BMW 325i
Old 10-11-2008 | 12:20 PM
JR.'s Avatar
JR.
i used oil and tq them down to like 110.
98 talon awd automagic
Old 10-11-2008 | 12:33 PM
Todd's90's Avatar
0711, USMC
do you think I can redo it one at a time with just the valve cover off?
1990 GS-T
1990 GST
2004 BMW 325i
Old 10-11-2008 | 12:39 PM
JR.'s Avatar
JR.
i dont see why not.
Old 10-11-2008 | 12:40 PM
Todd's90's Avatar
0711, USMC
I was not sure if taking out a stud one at a time would screw anything up. what kind of oil? just standard 30wt on the threads?
1990 GS-T
1990 GST
2004 BMW 325i
Old 10-11-2008 | 12:59 PM
JR.'s Avatar
JR.
dont take them out, just re-tq them.
Old 10-11-2008 | 04:41 PM
Neesan's Avatar
EL RIPPO
Ive taken just my valve cover off and applied more torque to head studs one at a time without any problems. I wouldnt worry about the lube on them now, theyll hold. If you take them out one at a time and do them then youll have that bothering you in the back of your mind.
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
Old 10-12-2008 | 09:18 AM
Black_Bullet's Avatar
**Dont disturb,Sleeping**
So I take it youll be needing the torque wrench again, and na dont take them out, keep in mind you tighten headstuds in a certain pattern...
Id just retorque them down to 100 ft/lbs or so without taking any off... That should be plenty fine for your goals...
Officially Dsmless...
"America remains one nation, under drugs, indivisible, with perceived liberty and sickness for all." - Shane Ellison
Old 10-12-2008 | 10:37 AM
Todd's90's Avatar
0711, USMC
I actually bought a torque wrench yesturday I'll just redo them tonight. the only reason I was talking about taking them out was because I did not oil them but they were alittle oily from previous use so they should be fine.
1990 GS-T
1990 GST
2004 BMW 325i
Old 10-12-2008 | 12:50 PM
ryu's Avatar
ryu
JUDGE RACING
The 1x1 headstud method is common practice in the Evo community when replacing headstuds although in your case there's no reason to remove them.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
