Aggravating recurring issue...any thoughts?
Old 01-05-2009 | 08:10 PM
vahz's Avatar
Default Aggravating recurring issue...any thoughts?
Hello. Recently bought a 97 Eclipse 2.0 non turbo. Its in decent shape just needs a few cosmetical repairs and maintance. Got a problem thats driving me crazy seems like something that should be easily fixed but I honestly have no idea what is going on or why. Here is the problem. When I bought it I was informed the tensioner pulley needed to be replaced which was causing problems with the p/s belt. No biggie. Got a new one straight from mitsubishi,got it installed- bought new belt ( also bought the alternator belt , figured Im going to be down there might as well get it replaced too). Got it installed everything fine and dandy. Later on that day the belt was split in two. From what I could see the belt seemed to slip from the bearings tracks and the grind of the bearing split the belt and basically the belt was done. My mechanic and myself we looked at the bearings and they all seemed to be fine and lined correctly. Thought that perhaps the belt was defective, got it replaced. And a day after I noticed it was starting to do the same thing ( belt sliping from the tracks ) but now it was also the alternator belt doing it too. So this is where I am at now. Car is parked and kinda wondering where to go with it as it hard to pin point the problem. The bearings are lined correctly, 2 belts have been installed, and have looked/research the interested for any similar threads and havent really found anything that shows rays of a solution to this. Any help or idea are greatly appreciated. Thanks.
Old 01-06-2009 | 05:43 AM
fallen4ng31's Avatar
Cogito ergo sum
Is the crank pulley in good shape? Also, is it an OEM or aftermarket. Pics would help. Also, you may wish to duplicate this post on 2GNT.com - home
"Kid, If you call me 'bro' one more time, I swear to Christ you're going to find out what your left testicle tastes like."
I offer professional computer / network services and consulting.
Over 10 years of industry experience.
A+/Network+/Security+ Certified ; CISCO CCNA, Novell CNA, Microsoft Certified IT Professional.
Old 01-06-2009 | 06:02 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
yep harmonic balancer/ crank pully ....happened to me heres tha link.......https://www.tamparacing.com/forums/m...good-news.html sorry pics dont work any more but im very sure thats what it is.....
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old 01-06-2009 | 06:05 AM
^ HIGH...My Name Is
my belts came off...maybe yours is broken in a different spot causing it to shred them. the wall holding the belt in place on mine was eaten away...maybe the tracks on yours are doing the same....
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
Old 01-06-2009 | 12:30 PM
dipstyc1928's Avatar
16g
have similar problem on my gsx. the bracket for my p/s pump is bent causing the pulley to be out of line so it's tearing my belt. i didn't even notice it until i actually stepped back from the car. you could have a similar problem.
THE PRICE IS WRONG BITCH!!!
Old 01-06-2009 | 06:53 PM
vahz's Avatar
Well first off, thank you all for the quick responses...really appreciate that , glad to see that the site actually has people that log on and communicate and help out others. Thanks appreciate that. Also glad to see that Im not the only one with this problem hehehe. And apparently its basically the same thing you guys have mentioned. And when i researched the problem... harmonic balancer also was mentioned. so i think that might solve it. I will take some pictures tomorrow and post em on here. Need-where did ya buy urs and if possible how much ? I bought my tensioner straight from mitsu, a bit expensive( yes oem ) but figured its better in the long run. Again thanks.
Old 01-06-2009 | 07:00 PM
^ HIGH...My Name Is
i got mine at tire choice i think...im sure they went thru napa....about a $400 fix...or you can look in a junk yard 4 1...i recomend brand new....
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
