blue car is down.
You really need to get that thing off the ass dyno. The power we have seen on ethanol has come much leaner than that on a gasoline wideband.
If you are tuning by what "feels" fast, then you very well may be gaining torque but not whp.
We have seen as high as 13.3 on ethanol, but run it richer than that.
probe is in middle of longest runner to extend life of probe. it runs about 50c cooler because of the position. I did experiment with tuning and had egt go as high as 850 at 12.5 A/F but it did not feel faster. Car felt strongest with more fuel at 10.8-11.0. most of the time I had egt hitting about 780. I played with the timing a few weeks ago and the egt was only hitting 700. felt stronger than ever.
I do believe the rod bent from pre ignition. I have been fighting misfire at peak torque. there may have been enough unburnt fuel at BDC to have ignitable mixture. damn wasted spark ignition.
I am leaning toward a built 2.3. car was so much fun with the 2.3/ 20g. its just worth breaking a tranny every now and then.
2005 Evo MR
715whp/595tq @ 50.5psi
10.1@143.3mph
Stock ECU
Pro Tuner
www.ttp-engineering.com
Mustang Dyno AWD-500-SE
2005 Evo MR
10.1@143.3mph
Stock ECU
Pro Tuner
Every set up is different and I was using alcohol injection not e85.
But I did inject a lot of alcohol and I can tell you my 35r set up made more power when my a/f was in low 11`s vs low 12`s to low 13`s
Tom
Tom
100% methanol on what jet size and kit?
2005 Evo MR
10.1@143.3mph
Stock ECU
Pro Tuner
2005 Evo MR
10.1@143.3mph
Stock ECU
Pro Tuner
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
Depending on the boost, it sounds pretty conservative.
2005 Evo MR
10.1@143.3mph
Stock ECU
Pro Tuner
2005 Evo MR
10.1@143.3mph
Stock ECU
Pro Tuner
I believe it was a 10:1 motor.
1993 Plymouth Laser - Eagle/Ross 2.0L, Kelford 272 cams, JMF SMIM, FIC 2150s, Precision 6765, ECMlink V3.
E85 32psi - 649FWHP, 444FWTQ. (ran out of injector).
I FIX AND TUNE (DSMlink & ECMlink) 4G63'S PM ME FOR DETAILS.
Are you talking about the motor that just let go? The motor was a stock internal evo8 setup.... 8.8:1 evo pistons/evo rods.
