420a engine fuse blowing
Old 09-22-2009 | 11:39 AM
bronxsoldier813's Avatar
Default 420a engine fuse blowing
i was driving down hills. my car just turned off engine wise radio and windows still in working condition i tried to restart and seen that my engine fuse was blown so i replaced it and tried to restart that fuse blew out with one start i have no idea what is going on could it be a short in the wires or something else please help any info a great help thank you
Old 09-22-2009 | 03:12 PM
wakeking48's Avatar
Yes!!!!
I had this problem in my old truck also, i couldnt figure it out and ended up takin it to a shop and all they could come up with was puttin a bigger fuse in it, the truck worked from then on?
Old 09-22-2009 | 04:48 PM
my car ran fine this morning i checked the alternator, spark plugs, starter, fuse box, fuel pump..... nothing out the ordinary besides the engine fuse. i did a tune up on sun changed the oil spark plugs
Old 09-23-2009 | 06:35 AM
found the problem it was a wire exposed touching the engine but thanks man for the help
Old 09-23-2009 | 07:30 AM
99_Clipse_GS's Avatar
Did you use the right fuse?
whats this
Old 09-23-2009 | 10:28 AM
yeah i used the right fuse i was sketchy on putting anything different bad things are possible to happen. using a bigger fuse i think would just make it easier for my wires to fry if it ever happened again and it will be to late if they do.
Old 09-23-2009 | 08:26 PM
Does it even try turn over? Or are you getting nothing? I blew my motor fuse a while back. I changed it out and it started right back up.
whats this
Old 09-24-2009 | 08:42 AM
well the car is fixed now it was a broken wire touching the engine itself so caused my fuses to burn out its just amazing because i had to get a tow home
