alternator help
alternator help
ok, so when my alternator is wired in, it's overcharging the system, which could explain why it fried my computer... however. we messured the volts in accessory, and the alternator output. the alternator is charging the battery up to about 19volts and the rest of the system to about 17.5-18.
we're gonna try swapping out the resister on the alternator(or whatever its called lol) but does anyone have input on the issue??
Napa part MPEVR38SB $14.99 voltage regulator.
The pigtail is ECHVRC38 and is less then $15
Frostbite- 95 mustang convert *SOLD*
Frostbite 2- 96 eclipse (custom) *SOLD*
Red Sled- 1989 Camaro RS *TRADED*
Bulldyke- 1981 K10 4x4 *RUSTY MUD TOY
Goatnutts- 1998 GSXR 750 SRAD *Traded*
Mario Kart- 98 civic ek w/ f22 swap *SOLD*
Lazarus- 90 Mustang LX Hatch *SOLD*
un-named- 86 trans am *SOLD*
Jailbate- 94 cbr 600 streetfighter *SOLD*
DD- 98 Astro
Michael- 87 camaro V8, 5 SPEED
DD- 98 Astro
Or go with the chrysler model regulator http://www.electromotive.us/pdf_files/neon99.pdf
scroll down to page 15 and it explains.
DD- 98 Astro
DD- 98 Astro
OH thats right lol, the ECU controls the voltage regulator. haha. easy fix at least!
does megasquirt not have a provision for voltage regulator signal?
but don't know. we've been hooking the alternator on inervals to keep the battery charged for test runs and until we figure something out. but i don't get paid till weds...
Yeah looks like you need an "add on" voltage regulator. Otherwise you could retain the stock ecu for that function but you're kinda outta luck on that front. Maybe you could find an ecu from a junkyard neon or something? I have a feeling that a separate voltage reg from another mitsubishi like John said is probably the cheapest, most straight forward solution though.
Oh and I dont know about anyone else, but I would not run that car at all with it charging upwards of 18v. Especially with your new shit all wired in.
were not dude lol. we're ground the alternator so it kicks on and then about 2 minutes later we're take it off. just so it charges the battery enough to run the ms lol
