Help Please 98 Eclipse Spyder Smoking
ive put together many motors i know what im doing.. but this one has me confused and yeah it has 140,500 miles on it and its non turbo everything is factory no mods im going to buy ARP Headbolts next time i bought the headbolts from napa this time i didnt reuse them.. and idk my spark plugs were as white as white can get that means their getting too hot
1994 CHEVY CAMARO-TRADED
1993 HONDA CIVIC SEDAN-TRADED
1992 HONDA CIVIC HATCH-SOLD
1995 EAGLE TALON ESI-TRADED
1990 PLYMOUTH LASER RS TURBO-SOLD
2003 MITSUBISHI ECLIPSE RS-SOLD
1997 HONDA CIVIC SEDAN-SOLD
1998 MITSUBISHI ECLIPSE SPYDERSOLD
1996 HONDA CIVIC EX GSR SWAP WITH B16 TRANNY TYPE R INTAKE MANI AND MUCH MORE - NOW HAVE
you have put many motors together but you wherent sure why the bolts would not torque? also you take a head off with 140k on it and don't recondition the head correctly the facts speak for them self. I wouldent be confused at all about this one. Its old has issues and needs fixed correctly.
the valves are fine idk about the valve seals tho im just gonna keep driving it till it gets worse
Ok so just an update I took off my exhaust manifold and found out number 1 and number 4 ports on the exhaust are leaking oil. So I'm thinking either my head gasket didn't seat all the way or my Valve Stem Seals are leaking. So once i get my new convertible top on my car just came in im going to order a brand new head and send them mine as a core.
shaft play, Leak down test, compression test, torques. Save money for fixing the problem once you find it(know what it is before you jump to fixing something). Small to big thats how the process goes. Plus one, homeboy called ya out sorry dude I agree. GL with the issue.
“It’s amusing to find that the road to success is never convenient however the road to failure all most always is...”
-S. Charles
"Excuses are monuments of nothing built by tools of inequity and those who use those tools will be masters of nothing"
-Unknown
"Time is a luxury that even the richest man cant buy"
-Unknown
1990 Talon TSi AWD
Joshua P.
-S. Charles
-Unknown
-Unknown
1990 Talon TSi AWD
Joshua P.
Well its obvious its the head so im buying a new one it will fix it
why in the world would you jump to conclusions.? you have not idea what the oil rings look like do you? or if you do i guess you look the pistons out and checked them all and just put the old rings back in huh. what is obvious here is that you did this job already.. took the head off did 1/3 of the stuff that needed to be done to it and installed it back on the car. now your just going to buy a new one. what happened to the valves are fine because i checked them. If the valves where fine you would only know that if you took every one out lapped them back into the head. checked the lapses and also while you where doing so then of course there would be new valve seals installed. I'm sorry my friend this was done half ass so you got a half ass job. i would suggest you take the engine apart and do the job 100% correctly but i know this isn't going to happen here. So i guess you should take the head back off do the other 2/3 work that needed to be done to it. Bolt it back on your car. Don't stretch the bolts again by other tightening them. Maybe it will not smoke anymore. And well if it does, all i can say is you should of done it 100% the first time. Man I've built over 200 plus 4G engines i know short cuts and where they can get you.
lol im not reading all these but if some said this then ignore me
first off, you redid the head and now your reving it to 5k?????? ever hear of break in time? need atleast 500 miles.... staying under 3k of easy driving.
sounds to me either one of 3 things:
1: valve stem seals are shot or they where wrecked from not being broken in
2: you fried the piston rings
3: head gasket wasnt trq right
Blue smoke is blow by of gas/oil mixed
Black is rich
grey is oil
white is coolant/carbon
Black is rich
grey is oil
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
91 Honda CRX Si
91 Honda Civic Si
I'll shorten it up... valves and seals old. Head bolts over torqued stretched bolts (he stated they just kept turning lol), rings all original. only work done which was milled head. 1/3 of the work that the head need to make sure the head was done right= over his head
Black is rich
grey is oil
Black is rich
grey is oil
Dude if you gonna talk shit on here just leave god damn im doing this so i know its done right my valves are fine maybe not the seals but my fuckin valves are perfect and like i said my stepdad is a fuckin airplain mechanic hes been there helping me so we do know what we are doing i did not take the springs out and the rockers and shit because there was no need to at the time so man like i said if you gonna talk shit GTFO Just saying I'm on here trying to get advice not hear some fuckin ass complain
