Spark plug gap verification or recommendations
I've looked around a few sites for possible gap sizes for the BPR7ES plugs I need to replace in my 03 EVO 8. On one site I found someone gapped theirs at .25, and someone else on that same page mentioned gapping theirs at .26. Another person had his at .29. I'm guessing this may be due to his setup (mods).
I previously had someone else do this for me, but I haven't received a response from him yet.
Current mods:
FPGreen
Injen intake with upper and lower hard pipes
TurboXS BOV
Megan downpipe
HKS exhaust
(will be getting 800cc or more injectors soon)
Thanks, any help would be appreciated.
Current mods:
FPGreen
TurboXS BOV
Megan downpipe
HKS exhaust
0.025 is fairly narrow - but realistically you are not going to physically be able to tell the difference between 0.025 and 0.026 - the human hand is not going to have the resolution of a thousandth of an inch.
0.029 will give you a better spark but only if your ignition can support that gap based on the boost pressure you are running.
(Keep in mind spark plug gaps are in hundredths of an inch, 0.25 as you mentioned is a full quarter of an inch and not an actual gap)
TIG Welder & Fabricator
thank you for the clarification, it was one of those "be careful what you read on the internet" i guess.
I believe i'm running at stock psi. I'lll be in desperate need of a tune after I get my hands on a set of new/larger injectors.
I thought i replied to the PM you sent me. YOu should start the gap at .024. Drive it and see if you get a miss fire during a pull. That should be a good gap. If you get a misfire set it down to .022.
JUDGE RACING
JUDGE RACING
