Evo VIII stock turbo dyno results
Old 05-17-2011 | 09:22 PM
  #21 (permalink)
fitbikeco's Avatar
you will understand one day sample with both and you will be amazed
Old 05-18-2011 | 04:09 AM
  #22 (permalink)
ryu's Avatar
ryu
JUDGE RACING
There is nothing further for me to understand. I appreciate that you are new to all of this and you are very impressionable with your new experience with ethanol and I'm happy for you that you appear to love your new found fuel. Ethanol has been around for quite a while now and I have already seen what it does on numerous occasions. There's nothing magical about it that would make me switch from methanol in a secondary fuel system.
If you want to compare real world results I'll be happy to share my 93oct+methanol comparison vs E85 cars that are using a higher ethanol content then someone with a secondary E100 injection kit. With 93oct+methanol I have one of the quickest stock turbo Evo's in the world vs all of the competition using E85-E98. There are only two other Evo's that have ran quicker due to substantial weight reduction. As for my FP Red setup, it has beaten David Buschurs personal fully built FP Red street car project of comparable weight and he was using E85 as well. Finally, my Evo stock block accomplishment that has put me in the 9's that only 4 Evo owners have ever done. The rest were using E85. As you can see with my 93oct+methanol injection setup I have managed to stay at the top of the competition. If methanol was such an inferior fuel, I would not be at the head of the pack as I am. Feel free to draw your own conclusions but I enjoy my fuel choice that keeps me toward the top of the leader board.
Stock turbo/Stock Block- 10.80@125.97mph
FP Red/Stock Block- 10.301@132.93mph
http://www.youtube.com/watch?v=k2CqirgpFeM
Hta3582 w-.63Tial/Stock Block- 9.96@139.83mph
http://www.youtube.com/watch?v=rxjaKUnUZNk
Tampa's Quickest Mitsubishi
JUDGE RACING
Join us on Facebook
http://www.facebook.com/#!/pages/Judge-Racing/203463879689026
Sponsored by:
MAPerformance
Old 05-18-2011 | 09:38 AM
  #23 (permalink)
fitbikeco's Avatar
yep i new to all this and so is drew
Old 05-18-2011 | 10:03 AM
  #24 (permalink)
cjackson2802's Avatar
lol. to each his own guys! 400whp on stock turbo is impressive. is it bone stock, or ported to all hell? and rich, i want more info on this e100. i was considering putting a cheap homemade meth kit on my car but where do you get e100 etc.
Old 05-18-2011 | 10:44 AM
  #25 (permalink)
danameisoj's Avatar
turbo is stock .. never been off the car. wastegate is untouched and it doesnt even have an aftermarket o2 housing.
one word of advice .. dont cheap out on an auxiliary injection setup.. it could cost you your engine.
NATT Certified
Old 05-18-2011 | 11:34 AM
  #26 (permalink)
fitbikeco's Avatar
i have question what happens when your meth pump fails.......
Old 05-18-2011 | 12:24 PM
  #27 (permalink)
ryu's Avatar
ryu
JUDGE RACING
I have yet to see a methanol pump flat out fail. The seals eventually swell and start to leak which will reduce pressure and slightly lean out your AFR. To someone who is aware of their setup and what is going on, it is very easy to catch right away. I've had pumps last anywhere between 6-12months.
In the extremely unlikely event that a pump should fail, a quality injection system such as the Aquamist setup has multiple built in fail safes that will cut your boost down to wastegate pressure instantaneously. If there is ever a methanol flow issue the fail safe makes it impossible to create a dangerous lean condition.
JUDGE RACING
Join us on Facebook
Sponsored by:
MAPerformance
Old 05-18-2011 | 12:26 PM
  #28 (permalink)
omgosh's Avatar
Well hopefully the failsafe will kick in as soon as line pressure drops. What happens when your fuel pump fails??
tr always trying to start shit..haha beat me too it ryu.
Old 05-18-2011 | 12:29 PM
  #29 (permalink)
ryu's Avatar
ryu
JUDGE RACING
JUDGE RACING
Join us on Facebook
Sponsored by:
MAPerformance
Old 05-18-2011 | 01:10 PM
  #30 (permalink)
danameisoj's Avatar
ive already tested my failsafe setup. i created a false flow/power loss just by turning off the system in mid pull and my failsafe dropped me down to 10psi instantly ...
also my system self tests as soon as you start the car and will only turn the system/boost on if the injection system is 100%
also in the event that i have insufficient flow the new flow monitor in the hfs-3 and 6 it triggers a fault in the flow portion of the control board that will turn off the injection system as well. im covered from many angles.
NATT Certified
Quick Reply: Evo VIII stock turbo dyno results
