The correct way to build an s14.
Old 04-22-2009 | 02:10 PM
  #331 (permalink)
longfellow2's Avatar
FORE:sight
Originally Posted by Silk_240
^ smart decision w/ the support. might have to come over and take a look this weekend man.
Sure thing
Originally Posted by Epstein
Old 04-22-2009 | 03:29 PM
  #332 (permalink)
PoorBoyBrian's Avatar
Body man extrordinair
just an idea here....
but i think you should put nuts and bolts in a few of the spot weld holes to further reinforce the front end. believe it or not but not having it properly secured will allow your front end to twist, bend, and do all sort of wonky things. and your front end lines wont hold very well either.
its a STRUCTURAL part of the front end and should be reinstalled accordingly.
Brian
Facebooks
Old 04-22-2009 | 04:02 PM
  #333 (permalink)
FORE:sight
It seems fine the way it is. Its already had to support my weight on multiple occasions and I have enough modified bracing on the front end that its not going to matter. And its not that stuctural. The bumper support is more structural than the core support on this car.
This biggest issue with the core support is to properly tie the hood down.
Old 04-22-2009 | 04:09 PM
  #334 (permalink)
i disagree but its your car and if you think its good enough, have at it.
Brian
Facebooks
Old 04-22-2009 | 08:30 PM
  #335 (permalink)
170k240's Avatar
Will Drift For Tires
i've done the same thing with the intake mani gasket before lol.
Nissan North America - Canton
Old 04-22-2009 | 08:33 PM
  #336 (permalink)
OneCleanS14's Avatar
hey you said you were getting nitto's right? when you get them what are you gonna do with the azeni's that are on your car now?
KA-T.
Enthalpy Tuned.
Old 04-22-2009 | 08:55 PM
  #337 (permalink)
FORE:sight
Do a sweet burn out then toss them. They are camber worn way past the wear bar.
Old 04-22-2009 | 08:59 PM
  #338 (permalink)
both fronts and rears?
KA-T.
Enthalpy Tuned.
Old 04-22-2009 | 09:00 PM
  #339 (permalink)
robunicu's Avatar
Nicolai
yey.. thx for the gas tank bro
PBM fender roller for rent!!
Old 04-23-2009 | 04:04 AM
  #340 (permalink)
Epstein's Avatar
Retired
It is not structural. Period. The structural members in the front end are the lower frame rails, the lower radiator support, and the upper rails that run to the strut tops. All of those members are multi-layer, heavy gauge steel. The core support is stamped single layer steel. All it does is hold up the headlights, top of the radiator, and hood latch. On the cars that followed the S-chassis, this part is plastic.
