My Kouki build. (First car, first project.)
Old 06-01-2010 | 07:40 PM
  #101 (permalink)
mazdaboy18's Avatar
working on it
good luck on the rebuild
-=1997 Mazda 626 traded
-=1993 Nissan 240sx hatch traded
-=1991 Nissan 240sx Coupe worst car ever Sold it
-=1987 Mazda Rx-7 non-turbo current
-=1994 Lexus SC-400 current
Need a tattoo? Discounts for mentioning TR
Old 07-16-2010 | 06:49 PM
  #102 (permalink)
E-Rod's Avatar
Default Epic update.
Auto Club of Tampa, Member #2
Old 07-16-2010 | 06:53 PM
  #103 (permalink)
SuburbanNoize's Avatar
Cold Ass Honky
Awesome! Its looking great!
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old 07-16-2010 | 07:48 PM
  #104 (permalink)
CheesePhantom's Avatar
Are YOU in the ACT?
Man, I'm so fucking proud of you. Just like Mohammad Ali recovering after a sick knock-out.
Bold Performance
Old 07-16-2010 | 11:30 PM
  #105 (permalink)
Taylorinalaska's Avatar
Mr. NiceGuy
very nice cleanup. I say fix the fender and door next.
Old 07-17-2010 | 09:35 AM
  #106 (permalink)
E-Rod's Avatar
Hahaha. Thank, guys. Yeah, I'm gonna beat the shit out of that fender pretty soon.
Still waiting on glass corner lights... IntensePower.com is taking forever.
Old 10-28-2010 | 10:52 AM
  #107 (permalink)
E-Rod's Avatar
Update:
Damaged sideskirt, STILL no corner lights.
Bent rod shot through lower block.
Working on getting a new block and the tools necessary to swap the shit out.
I've never pulled a motor before, but I've Googled and now have a fair idea of what must be done. Still, any advice would be helpful.
Surprisingly, I'm a bit more excited than upset about it. Pulling the block and a taking it apart will be a learning experience. Also, if all goes well, I'll be doing a five-speed swap while the motor's out. With that, I could really use some help or adive or something. I've seen guides all over, but I could definitely use help in the form of advice or handwork.
More later. Peace, TR.
Old 10-28-2010 | 11:33 AM
  #108 (permalink)
dan's Avatar
dan
Get the fuck off my lawn
Corner lights are cheap (and they're not glass). Just go down to Nissan and order some.
Engine swap isn't horrible, just requires a few pairs of hands and knowledge on what to unplug and drain. Undo wiring, drain coolant, remove intake and header, remove fans/radiator/hoses/disconnect heater hoses. Loosen engine mounts and transmission mount, disconnect driveshaft (possibly drain tranny oil). There's lots of misc brackets to get rid of too before you yank it.
Good time to do a 5 speed swap. You'll need the driveshaft, proper flywheel/clutch, pedal, line, shifter/tranny (obviously).
During rebuild, be sure to check on the timing chains and tensioners, the front/rear main seals, any gaskets you encounter, and also the mess of hoses under the intake manifold (prepare to be wowed by how many there are). You can block off the EGR and basically remove almost all of the emissions stuff except for the IACV. Make a list and head down to Nissan (or check courtesyparts.com or whatever it is now), and get the OE stuff - it's worth it and it's not that expensive.
Old 10-28-2010 | 11:44 AM
  #109 (permalink)
Invader_Zim's Avatar
Typical TR Asshole
what dan said
ಠ_ಠ Haters gonna hate ಠ_ಠ
Old 10-29-2010 | 06:50 AM
  #110 (permalink)
E-Rod's Avatar
Hell yeah, thank you. Saw this and am considering:
https://www.tamparacing.com/forums/n...ess-400-a.html
