Alex's 2JZ 180SX / FAB WORK BY HMS
SEE THE REST HERE: https://www.tamparacing.com/forums/h...jz-180sxb.html
Alex is now finishing up on the 180sx, And had a few things he wanted us to do.
- 3"SS Downpipe.
- 3"MS Downpipe-back Exhaust.
- Wastegate dumptube
- Intercooler system
- Etc.
Huge! front mount installed.
The downpipe was a tricky, because the steering is on the same side as exhaust not much room to work with. you can see the turbine housing @ the bottom of the image.
Anyway got it done: nothing is too hard for our trusty miller syncrowave 200
DP minus the o2, egt bungs & exhaust flange
DP installed , o2 bung in.
good clearance shot from underneath.
- 3"SS Downpipe.
- Etc.
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum: https://www.tamparacing.com/forums/hybrid-motorsports/
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
looking good guys. What ems?
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
My shit still slow
some more on it:
Ok well parts came in, so picking up where we left off.
The wastegate feed pipe from the manifold to the wastegate, was too long & flange was facing the wrong direction and had to be modified.
Modified & installed
While we wait for the dumptube material, we'll start on the intercooler piping.
From prior experience with this swap, We knew we would encounter a tight space between the radiator & throttle body so we went ahead & modified it. This time taking off, 1 15/16th" !!
Hotside:
Complete hotside piping:
The battery was already relocated to the hatch, so we cleaned up a bit & made use of the unused space.
Hotside installed:
Complete cold side piping:
Cold side installed:
Shot of both sides:
In a few early shot you might be able to see the radiator top side feed was on the left side of the car, but we decided to switch it out for a right side feed for a cleaner & simpler setup. So now we had to modify the water neck:
Before:
After:
Hotside:
Hotside installed:
Shot of both sides:
Before:
After:
So moving onto the exhaust downpipe back:
Flex that bolts to dp.
Complete system: downpipe back!
Installed:
Also the customer requested we figure out a means of mounting his power steering pump, the reason being, he's no longer running a/c and on the 2j's the power steering use the a/c to mount......anyways.
We came up with a nifty little bracket.
Installed:
Well we have come to the end of this build, We are happy the way things turned out & The customer was also pleased, we were able to fulfill all of His requests.
Before sending the car home , We Decided to revise the dumptube by extending an additional 4".
Exhaust ground clearance:
Parting shots:
^ Alot of people should get use to this view
Thanks for viewing. (The end)
Parting shots:
The results were amazing bone stock (jdm) engine , gt3582r 9psi on an afc (no timing control)
405rwhp & 331ft/lbs tq.
Video: YouTube - VIDEO0022
