need help with harmonic balancer vh45
Old 09-06-2014 | 04:44 AM
I also have more belt grooves than I once needed. As I added more stuff, I used them.
The stock pulley saved me having to buy another one later. Since I don't need power
steering for a small car, that one will remain empty.
Originally Posted by Blazin'240sx
i figured out what i need. i need one from a q45 without 4 wheel steering (12303-60U21). whats the difference between the two? is it just the amount of belts it can hold, it is for the same engine after all so they both should absorb the vibrations the same unless (from what i thought before i started this thread) each balancer was designed for the specific motor its going on because 2 of the same engines may not run the exact same.
Alan
01-11-2008 10:28 AM
98gsturbo
10-25-2007 03:08 PM
