fuel pump problems
yea sweet lemonade
on
fuel pump problems
sr, 480cc's, walbro, i keep going threw walbro's! is there a reason why or a way i can stop this from happening. is it the wireing or the thingy in the tank? i'm sick of having fuel delivery problems.
Enthalpy's post on FA:
http://forums.freshalloy.com/ubbthre...e#Post67635277
also,
http://forums.freshalloy.com/ubbthre...e#Post67933549
also,
Guest
Posts: n/a
[QU073=cy4|\|1d3]3|\|7h4lpy'5 p057 0|\| F4:
[u|2l]h77p://f0|2um5.f|235h4ll0y.c0m/ubb7h|234d5/5h0\^/fl47.php?C47=&B04|2d=UBB9&|\|umb3|2=67635277&F0|2u m=UBB9&\^/0|2d5=fu3l%20pump%20|23l4y&M47ch=4|\|d&534|2chp4g3 =0&L1m17=25&0ld=4llp0575&M41|\|=67635188&534|2ch=7 |2u3#P05767635277[/u|2l]
4l50,
[u|2l]h77p://f0|2um5.f|235h4ll0y.c0m/ubb7h|234d5/5h0\^/fl47.php?C47=&B04|2d=UBB9&|\|umb3|2=67933549&F0|2u m=UBB9&\^/0|2d5=fu3l%20pump%20\^/1|23&M47ch=4|\|d&534|2chp4g3=1&L1m17=25&0ld=4llp05 75&M41|\|=67933549&534|2ch=7|2u3#P05767933549[/u|2l][/QU073]
d4m|\| 1 7h0ugh7 7h15 \^/45 c0mm0|\| k|\|0\^/l3dg3 by |\|0\^/ f0|2 5135
4l50,
Originally Posted by John
damn i thought this was common knowledge by now for S13s
It's an easy enough fix, could be way worse. Initally, I did mine in the parking lot of an Advance auto with some cheesy foglight wiring kit. Glad my battery was in the back.
what exactly does it make the car do cause i think that my car has the fuel pump bad or something but im not sure. It drives really slow and ill stomp it u can hear it loud as hell but its accelerating really slow. let me know if that what the pump does because i just dont want to replace the fuel pump if its not the problem.
Another good point that I should mention: don't run your tank dry before refueling with an upgraded fuel pump. The pumps make more heat due to their increased capacity and the gasoline is basically a heat exchanger. If the pump is un-immersed more than it is actually immersed, expect less pump life as well.
